Failed to start BIND Domain Name Server
yanistyle
Сообщение yanistyle » Вт фев 20, 2024 11:18 am
Добрый день! Отвалился BIND сервер на двух панелях которые хостятся в разных местах. В панели статус Named горит красным.
Логи:
Feb 20 14:06:05 nl named[5795]: BIND 9 is maintained by Internet Systems Consortium,
Feb 20 14:06:05 nl named[5795]: Inc. (ISC), a non-profit 501(c)(3) public-benefit
Feb 20 14:06:05 nl named[5795]: corporation.  Support and training for BIND 9 are
Feb 20 14:06:05 nl named[5795]: available at https://www.isc.org/support
Feb 20 14:06:05 nl named[5795]: ----------------------------------------------------
Feb 20 14:06:05 nl named[5795]: adjusted limit on open files from 524288 to 1048576
Feb 20 14:06:05 nl named[5795]: found 2 CPUs, using 2 worker threads
Feb 20 14:06:05 nl named[5795]: using 2 UDP listeners per interface
Feb 20 14:06:05 nl named[5795]: netmgr.c:265: fatal error:
Feb 20 14:06:05 nl named[5795]: libuv version too new: running with libuv 1.40.0 when compiled with libuv 1.34.2 will lead to libuv failures
Feb 20 14:06:05 nl named[5795]: exiting (due to fatal error in library)
Feb 20 14:06:06 nl systemd[1]: named.service: Main process exited, code=dumped, status=6/ABRT
Feb 20 14:06:06 nl systemd[1]: named.service: Failed with result 'core-dump'.
Feb 20 14:06:06 nl systemd[1]: named.service: Scheduled restart job, restart counter is at 5.
Feb 20 14:06:06 nl systemd[1]: Stopped BIND Domain Name Server.
Feb 20 14:06:06 nl systemd[1]: named.service: Start request repeated too quickly.
Feb 20 14:06:06 nl systemd[1]: Failed to start BIND Domain Name Server.
Re: Failed to start BIND Domain Name Server
Сообщение alenka » Вт фев 20, 2024 11:40 am
rpm -qa | grep bind
или
dpkg -l | grep bind
yanistyle
Сообщение yanistyle » Вт фев 20, 2024 12:08 pm
rpm -qa | grep bind
или
dpkg -l | grep bind
ii  bind9                                 1:9.16.48-0ubuntu0.20.04.1            amd64        Internet Domain Name Server
ii  bind9-dnsutils                        1:9.16.48-0ubuntu0.20.04.1            amd64        Clients provided with BIND 9
ii  bind9-host                            1:9.16.48-0ubuntu0.20.04.1            amd64        DNS Lookup Utility
ii  bind9-libs:amd64                      1:9.16.48-0ubuntu0.20.04.1            amd64        Shared Libraries used by BIND 9
ii  bind9-utils                           1:9.16.48-0ubuntu0.20.04.1            amd64        Utilities for BIND 9
ii  libatk-wrapper-java-jni:amd64         0.37.1-1                              amd64        ATK implementation for Java using JNI (JNI bindings)
ii  libnet-libidn-perl                    0.12.ds-3build2                       amd64        Perl bindings for GNU Libidn
ii  libwbclient0:amd64                    2:4.15.13+dfsg-0ubuntu0.20.04.7       amd64        Samba winbind client library
ii  php74w-litespeed                      7.4.33-1                              amd64        The php-litespeed package provides the %{_bindir}/lsphp command
ii  php74w-pq                             2.2.0-3                               amd64        PostgreSQL client library (libpq) binding.
ii  php81w-litespeed                      8.1.23-0brainy0.20.04                 amd64        The php-litespeed package provides the %{_bindir}/lsphp command
ii  php81w-pq                             2.2.1-1.18.brainy                     amd64        PostgreSQL client library (libpq) binding.
ii  python3-commandnotfound               20.04.6                               all          Python 3 bindings for command-not-found.
ii  python3-gi                            3.36.0-1                              amd64        Python 3 bindings for gobject-introspection libraries
ii  python3-ldb                           2:2.4.4-0ubuntu0.20.04.2              amd64        Python 3 bindings for LDB
ii  python3-nacl                          1.3.0-5                               amd64        Python bindings to libsodium (Python 3)
ii  python3-pyinotify                     0.9.6-1.2ubuntu1                      all          simple Linux inotify Python bindings
ii  python3-systemd                       234-3build2                           amd64        Python 3 bindings for systemd
ii  python3-talloc:amd64                  2.3.3-0ubuntu0.20.04.1                amd64        hierarchical pool based memory allocator - Python3 bindings
ii  rpcbind                               1.2.5-8                               amd64        converts RPC program numbers into universal addresses
Cramac
Сообщение Cramac » Ср фев 21, 2024 6:47 am
таже история.
# dpkg -l | grep bind
ii  php56w-litespeed                      5.6.40-20.1                           amd64        The php-litespeed package provides the %{_bindir}/lsphp command
ii  php56w-pq                             1.1.1-2                               amd64        PostgreSQL client library (libpq) binding.
ii  php72w-litespeed                      7.2.34-1.1                            amd64        The php-litespeed package provides the %{_bindir}/lsphp command
ii  php72w-pq                             2.2.0-3                               amd64        PostgreSQL client library (libpq) binding.
ii  php74w-litespeed                      7.4.24-1.1                            amd64        The php-litespeed package provides the %{_bindir}/lsphp command
ii  php81w-litespeed                      8.1.18-1.1.brainy                     amd64        The php-litespeed package provides the %{_bindir}/lsphp command
bind9 автообновился как раз 20 числа.
Cramac
Сообщение Cramac » Ср фев 21, 2024 9:00 am
стоит в ручную пробовать собрать или подождать решения?
мой косяк, секондри сервер так и не запустил, все сайты легли :(
Cramac
Сообщение Cramac » Ср фев 21, 2024 9:33 am
решил проблему откатив библиотеки:
apt install libuv1=1.34.2-1ubuntu1.3
Сообщение sbury » Ср фев 21, 2024 10:10 am
выполнить
apt-get update
переустановить bind в панели
Cramac
Сообщение Cramac » Ср фев 21, 2024 10:53 am
спасибо за обновление, все норм
Cramac
Сообщение Cramac » Ср фев 21, 2024 12:00 pm
А обновление не могло конфиг сломать? А то что то dig пустой ответ дает
Сообщение alenka » Ср фев 21, 2024 1:05 pm
Попробуйте обновить кеш днс зон, и перегрузить намед
