По какой причине не устанавливается MariaDB?
T3G1NG
Сообщение T3G1NG » Вс июл 29, 2018 1:16 pm
Добрый день, вопрос в названии. В логах пока-что слабоват. В чём трабл?
/etc/brainy/ssh/mysql.php -a=install -s=MariaDB10.3 >>/etc/brainy/data/streams/mysql_mysql_install_153286969125174 2>>/etc/brainy/data/streams/mysql_mysql_install_153286969125174
Starting install MySQL MariaDB10.3
error: rpmdb: BDB0113 Thread/process 25278/140509591435072 failed: BDB1507 Thread died in Berkeley DB library
error: db5 error(-30973) from dbenv->failchk: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery
error: cannot open Packages index using db5 -  (-30973)
error: cannot open Packages database in /var/lib/rpm
rpm: no packages given for erase
Install MySQL MariaDB10.3
CRITICAL:yum.main:
Error: rpmdb open failed
Starting postinstall
chown: cannot access '/var/lib/mysql/': No such file or directory
END OF INSTALL
/etc/brainy/src/compiled/php5/bin/php -q /etc/brainy/ssh/monitor/scaner.php > /dev/null 2> /dev/null
UPD: Перезагрузил VDS и теперь показывает следующие, это как я понял, сервер пакетов не доступен. Как быть?)
/etc/brainy/ssh/mysql.php -a=install -s=MariaDB10.3 >>/etc/brainy/data/streams/mysql_mysql_install_153287266359041 2>>/etc/brainy/data/streams/mysql_mysql_install_153287266359041
http://185.143.145.19/centos/7/x86_64/repodata/repomd.xml: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
Trying other mirror.
http://185.143.145.19/centos/7/x86_64/exim-mysql10.3-4.91-1.el7.centos.x86_64.rpm: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
http://185.143.145.19/centos/7/x86_64/dovecot-mysql10.3-2.2.27-10.el7.centos.x86_64.rpm: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
http://185.143.145.19/centos/7/x86_64/mariadb10.3-10.3.7-10.el7.centos.x86_64.rpm: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
http://185.143.145.19/centos/7/x86_64/mariadb10.3-common-10.3.7-10.el7.centos.x86_64.rpm: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
http://185.143.145.19/centos/7/x86_64/mariadb10.3-libs-10.3.7-10.el7.centos.x86_64.rpm: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
http://185.143.145.19/centos/7/x86_64/mariadb10.3-server-10.3.7-10.el7.centos.x86_64.rpm: [Errno 14] curl#7 - "Failed connect to 185.143.145.19:80; No route to host"
Error downloading packages:
  4:mariadb10.3-server-10.3.7-10.el7.centos.x86_64: [Errno 256] No more mirrors to try.
  1:dovecot-mysql10.3-2.2.27-10.el7.centos.x86_64: [Errno 256] No more mirrors to try.
  4:mariadb10.3-libs-10.3.7-10.el7.centos.x86_64: [Errno 256] No more mirrors to try.
  4:mariadb10.3-common-10.3.7-10.el7.centos.x86_64: [Errno 256] No more mirrors to try.
  exim-mysql10.3-4.91-1.el7.centos.x86_64: [Errno 256] No more mirrors to try.
  4:mariadb10.3-10.3.7-10.el7.centos.x86_64: [Errno 256] No more mirrors to try.
 * base: mirror.reconn.ru
 * extras: mirror.reconn.ru
 * updates: mirror.reconn.ru
Resolving Dependencies
--> Running transaction check
---> Package dovecot-mysql10.3.x86_64 1:2.2.27-10.el7.centos will be installed
--> Processing Dependency: libmariadb.so.3(libmysqlclient_18)(64bit) for package: 1:dovecot-mysql10.3-2.2.27-10.el7.centos.x86_64
--> Processing Dependency: libmariadb.so.3()(64bit) for package: 1:dovecot-mysql10.3-2.2.27-10.el7.centos.x86_64
---> Package exim-mysql10.3.x86_64 0:4.91-1.el7.centos will be installed
---> Package mariadb10.3-server.x86_64 4:10.3.7-10.el7.centos will be installed
--> Processing Dependency: mariadb10.3-common(x86-64) = 4:10.3.7-10.el7.centos for package: 4:mariadb10.3-server-10.3.7-10.el7.centos.x86_64
--> Processing Dependency: mysql-compat-client(x86-64) for package: 4:mariadb10.3-server-10.3.7-10.el7.centos.x86_64
--> Processing Dependency: mysql(x86-64) for package: 4:mariadb10.3-server-10.3.7-10.el7.centos.x86_64
---> Package mariadb10.3.x86_64 4:10.3.7-10.el7.centos will be installed
---> Package mariadb10.3-common.x86_64 4:10.3.7-10.el7.centos will be installed
---> Package mariadb10.3-libs.x86_64 4:10.3.7-10.el7.centos will be installed
Dependencies Resolved
 Package              Arch     Version                    Repository       Size
Installing:
 dovecot-mysql10.3    x86_64   1:2.2.27-10.el7.centos     brainy-second    11 k
 exim-mysql10.3       x86_64   4.91-1.el7.centos          brainy-second   7.9 k
 mariadb10.3-server   x86_64   4:10.3.7-10.el7.centos     brainy-second    22 M
Installing for dependencies:
 mariadb10.3          x86_64   4:10.3.7-10.el7.centos     brainy-second   6.0 M
 mariadb10.3-common   x86_64   4:10.3.7-10.el7.centos     brainy-second    28 k
 mariadb10.3-libs     x86_64   4:10.3.7-10.el7.centos     brainy-second   312 k
Transaction Summary
Install  3 Packages (+3 Dependent packages)
Total download size: 29 M
Installed size: 147 M
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.Starting postinstall
END OF INSTALL
Re: По какой причине не устанавливается MariaDB?
Сообщение sbury » Пн июл 30, 2018 10:09 am
День добрый.
выполните из командной строки
wget http://core.brainycp.com/repo_update.sh && bash ./repo_update.sh
dmitry_stas
Сообщение dmitry_stas » Вт июл 31, 2018 9:14 am
а 10.3 уже доступна для установки? можно смело ставить?
P.S. все поставилось отлично :)
